unconfigure ip-security dhcp-snooping information remote-id
Description
Removes the DHCP relay agent remote ID.
Syntax Description
Default
After using this command, or if the remote ID has not been configured, the default remote ID is the switch's MAC address.
Usage Guidelines
This command removes the remote ID set by the configure ip-security dhcp-snooping information remote-id [system-name |remote-id_info] command. After running this command, or if the remote ID has never been configured, the default remote ID is the switch's MAC address. However, this default (MAC address) name does not appear in the show ip-security dhcp-snooping information remote-id command.
The following command removes the DHCP remote ID:
# unconfigure ip-security dhcp-snooping information remote-id
Platform Availability
